PLCnext Engineer cannot find the Codemeter license (error 200).
We have the following problem in our training lab:
In fact, there is no license in the CodeMeter Control Center.
We have tried several solutions (based on older answers in the forum on this topic):
- PLCnext Eng. reinstallation and/or repair
- We tried different PLCnext Eng. versions (2024.6, 2023.0.5, 2024.0.4, 2022.0.)
- Deleting the AppData data from the PHOENIX CONTACT directory after uninstall
- Deleting the Code-Meter data from the CmAct directory and then reinstalling PLCnext Eng
We have tried many different combinations of the above steps.
Manual activation of the Basic License using the Activation Wizard is also not possible.
We were only able to import the emergency license, which is not an option for our internship lab due to the limited usage period (4 days).
Windows 11 - 22631.4317
Activation Wizard 1.7.1
CodeMeter Control Center 8.10a
Reinstalling the computer is not an option at the moment, which is why we would be very grateful for any suggestions for activating the basic license.
Regards,
Tom
  • The problem is still not solved!
    I uninstalled all software from phoenix, wibu(Codemeter) and purged all remaining registry entries containing "Phoenix", "CodeMeter" and "wibu".
    Booting machine 2 times and fresh installation of PLCnext Engineer 2023.0.5 results in the same problem, i.e. no licence found (200).
    The CodeMeter Control log shows:
    2024-11-01 14:36:13: proxy: system proxy (upgrade) - host: '', user: ''
    2024-11-01 14:36:13: Named User: License Tracking not activated
    2024-11-01 14:36:13: AccessControl: Could not find primary domain.
    2024-11-01 14:36:13: CodeMeter for Windows (B7.51.5429.500.32.1000)
    2024-11-01 14:36:13: Running on Microsoft Windows 11 Professional 23H2, 64-Bit
    2024-11-01 14:36:13: Execution path: C:\Program Files (x86)\CodeMeter\Runtime\bin
    2024-11-01 14:36:13: Found IPv4 address: 127.0.0.1 | 172.17.96.1 | 192.168.178.103 | 192.168.56.1
    2024-11-01 14:36:13: Found IPv6 address: ::1 | fe80::35f3:8602:8d85:4059%13 | fe80::4047:c74:e479:63ed%12 | fe80::649e:5856:cefb:cf04%62 | fe80::6be4:a5f7:40b8:c55b%19 | fe80::a446:eb1c:188f:15ae%27 | fe80::b1d9:c3b2:f4a4:7a96%8 | fe80::f6c5:64c2:66f5:2c05%14
    2024-11-01 14:36:13: Used Communication Mode (Client): IPv6 IPv4 SharedMemory
    2024-11-01 14:36:13: Used Communication Mode (Server): IPv6 IPv4 SharedMemory
    2024-11-01 14:36:13: Used IP address: 127.0.0.1
    2024-11-01 14:36:13: Used IP port: 22350
    2024-11-01 14:36:13: Used CmWAN port: 22351
    2024-11-01 14:36:13: Run as network server: no
    2024-11-01 14:36:13: Run as CmWAN server: no
    2024-11-01 14:36:13: Run as system service: yes
    2024-11-01 14:36:13: Service startup delay: 3:11 minutes
    2024-11-01 14:36:13: TMR-Mode: disabled
    2024-11-01 14:36:13: Box Access: use direct access mode
    2024-11-01 14:36:17: The list of available CmContainers has been updated!
    2024-11-01 14:36:18: The list of available CmContainers has been updated!
    2024-11-01 14:36:18: Server ready
    2024-11-01 14:36:18: Startup duration: 5 seconds
    2024-11-01 14:36:26: Access from local(IPV4) to SubSystem (Handle 18)
    2024-11-01 14:36:26: Handle 18 released
    2024-11-01 14:39:25: Access from local(IPV4)(pdv-3\mtm) to SubSystem (Handle 19)
    2024-11-01 14:39:25: Unknown exception2024-11-01 14:39:25: API Event WB233 (UPDATE FAILED) occurred (returned to caller)
    2024-11-01 14:39:25: Handle 19 released
    2024-11-01 14:39:26: Access from local(IPV4) to SubSystem (Handle 22)
    2024-11-01 14:39:26: Handle 22 released
    2024-11-01 14:41:47: Access from local(IPV4)(pdv-3\mtm,PLCNENG64) to SubSystem (Handle 23)
    2024-11-01 14:41:47: Handle 23 released
    2024-11-01 14:41:47: Executing Broadcast for CodeMeter License Servers
    2024-11-01 14:41:48: Entry (6000217:1001000) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(pdv-3\mtm,PLCNENG64) (SID 0xc03d / 0x00) with StationShare Mode
    2024-11-01 14:41:48: API Error 200 (ENTRY NOT FOUND) occurred!
    2024-11-01 14:41:53: Entry (6000217:1001000) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(pdv-3\mtm,PLCNENG64) (SID 0xc03d / 0x00) with StationShare Mode
    2024-11-01 14:41:53: API Error 200 (ENTRY NOT FOUND) occurred!
    Any hints?
    Best Regards
    Tom
  • Hello,
    problem has been solved due to great support by Phoenix contact.
    Thanks!
  • edited February 3
    Hi @tom
    I am facing the same problem as you. It would be very helpful if you could share the solution you got.
    Thanks!
