I have the same error. However I believe that it was a consequence of the error I make to install PC Worx Engineering first. Please let me know what I can do.
I need to restart the computer to use the PLCNext Engineering software again. I try to restart the program I can not do it. I have windows 11 PRO.
By mistake I install as a first option the PC Worx Engineer 7.2.3
Since then after some minutes , one hour i have and error message.
Also If I do not use the PLCNext Engineer program the message appears after some time. I have the message after I use other PLC software from ICLinks and Unilogic. And I can not start PLCNext Engineer program I need to restart the PC.
How I can fix the problem . I would appreciate any solution you can give me.
Thank you for the information. The problem become worst. I turn on PLCNext and the error arrives. I go to Control center, it is the first time I use it. I have no idea of this program. I have two license one for PLCNext and One for PC Worx. I make the mistake to install PC Worx at the begining. I try to erase the PC Wors license, but I can not do it. I update the certificate time and I solve the problem today. If you have and idea to have a permanent solution I will appreciate. Thank you
I have the license for some E&H sensors and the Phoenix Contact PLC.
please point out where and with which software version you get above mentioned error.
Please type CodeMeter Control Center in Windows search and check, if there is PLCnext Engineer basic license
first of all, please check in CodeMeter Control Center, there should be license PLCnext Engineer Basic License:
and check if license is active
If not, then please go to File -> Import License
and find catalogue:
C:\Program Files\Phoenix Contact\PLCnext Engineer 20xx.x\Licenses
and import PLCnext Engineer_BasicLicense.WibuCmRaU
and check if problem is solved.
license is active. But when a license error occurs, the CodeMeter service stops. I have to start it manually.
PLCnext Engineer vers.
some log strings
please update the codemeter runtime.
Following link can be used:
Software für Anwender - Wibu-Systems
2024.0.4. has an older version in his release roleout.
