HMI Button Hover Color
edited November 2024 in PLCnext Engineer
When moving the mouse over a button, it is displayed slightly grayed out.
If the HMI is used with a touch, this grayed out unfortunately remains when the button is pressed.
Is it possible to deactivate this property for the button?
  • Hello, the button is displayed slightly grayed out as long as the focus is on it. This cannot be deactivated.
  • Maybe by changing the color to transparant?
  • beecksche,
    I had this same issue and could not find a way to remove it when using a button object. I talked with a colleague and he had the answer. Since this is a html (web) based system, you can make a button out of almost anything. So, if you need a rectangle button, instead of using the button object, just bring in a rectangle object then make that rectangle do the action you want. you can also do this with your text so you dont have to layer so many objects to create the effect you desire. Keep in mind that each object has different dynamics and options. This will make some pros and cons for what you use although, this also allows for a wide range of control in this system. I would love to know if this fixes your issue.
    CHEERS
  • Thank you for your answer. I have also thought about a custom button as a symbol. Simply a rectangle with action dynamics. However, I need different icons for the buttons. And unfortunately I can't realize that with symbols. And creating a separate icon for each button seems too time-consuming.
  • can you give a couple examples of your needs. I would like to try and help if possible. I am still very new to this system but I can reach out to others as well.
