Error when importing GSDML files for FL IL 24 BK-PN-PAC-V1.0 modules
When using PLCnext Engineer 2024.0.4 (Build 7.0.550.0, Revision ba77587a) and the AXC F 2152 starter kit I get an issue when importing the GDML files for the FL IL 24 BK-PN-PAC => https://www.phoenixcontact.com/en-pc/products/bus-coupler-fl-il-24-bk-pn-pac-2878816
The error: Error,"10/12/2024 14:10:36","MSG_NET0036","Failed to import device FL IL 24 BK-PN-PAC-V1.0. The Profinet version V1.0 is < 2.2. (C:\Users\Michael\Downloads\GSDML_FL_IL_24_BK_PN_20131015\GSDML-V2.3-Phoenix Contact-FL IL 24 BK-PN-V2.11-20131015.xml)"
The name of the GSDML file on the website states V2.3.
I already tried to change the PNIO_Version attribute to V2.3 but the I get the following error when importing to PLC next Engineer:
Error,"10/12/2024 14:54:06","MSG_NET0036","Failed to import device FL IL 24 BK-PN-PAC-V1.0. Interface submodule is missing. (C:\Users\Michael\Downloads\GSDML_FL_IL_24_BK_PN_20131015_3\GSDML-V2.3-Phoenix Contact-FL IL 24 BK-PN-V2.11-20131015.xml)"
This is a problem because we have bought 20 starterkits after we where informed it should not be an issue to use it with our current IL PN stations (Whe have all different kind of older modules).
Can somebody help us with this please?
  • Hi
    I'm sorry to inform you this, but PLCnext Engineer requires at least a GSDML Profinet version 2.2 as described in the system properties.
    I asked the BK product developers but they told me the module has been discontinued for almost 10 years, and you should use the successor: IL PN BK-PAC - Kopstation - 2403696 | Phoenix Contact
    You say that you have all kinds of older modules, which ones? Maybe some of them do have Profinet version 2.2 or higher.
    For future problems/questions, might I suggest you contact the Belgian Automation support directly: axsupport@phoenixcontact.be
    Best regards
    Mathieu
