Connecting MATLAB/Simulink with AXC F 2152 controller
Hello. I am new to PLC. I have AXC F 2152 controller. I want to connect my controller with MATLAB/Simulink software. How to establish profinet communication between them? Kindly can anyone guide me on this?
  • edited December 2024
    If you want to establish Profinet communication, then I assume that the Matlab/Simulink software has Profinet communication capability - is that correct?
    If so, does the device running the Matlab/Simulink software act as a Profinet controller or a Profinet device?
    If it's a Profinet device, do you have a GSDML file for the device?
    If it's a Profinet controller, you should be able to import the GSDML file for the AXC F 2152 into the Matlab/Simulink IDE. The GSDML file for the AXC F 2152 can be downloaded from the website, here:
    https://www.phoenixcontact.com/en-pc/products/controller-axc-f-2152-2404267#downloads-link-target
  • Hello Martin, I am gonna run my simulink model on a raspberry pi model 4. So is it possible to communicate raspberry pi with 2152 PLC?
  • Hello.
    The answer is the same regardless of what device the Simulink model is running on.
    What communication interfaces does Simulink provide for communicating with partner devices? Profinet? OPC UA? Modbus/TCP? If Simulink provides a suitable communication interface, then it should be possible for the model to communicate with an AXC F 2152.
    Have you considered running the Simulink model directly on the AXC F 2152?
