network connection is lost for no reason
Good day!
During operation, the controller loses connection with the network device and does not restore it. The only thing that helps is switching the controller to the "STOP" mode, and then to the "START" mode, or rebooting. Although the end device is available for connection by any device.
The BUSY lamp is on at the TLS_SOCKET pin, HANDLE = 0
Here is an excerpt from the controller log:
08.01.25 13:01:10.344 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Link" not found
08.01.25 13:01:10.356 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Duplex" not found
08.01.25 13:01:10.361 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Baudrate" not found
08.01.25 13:01:10.937 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Link" not found
08.01.25 13:01:10.948 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Duplex" not found
08.01.25 13:01:10.968 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Baudrate" not found
08.01.25 13:01:11.432 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Link" not found
08.01.25 13:01:11.436 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Duplex" not found
08.01.25 13:01:11.442 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Baudrate" not found
08.01.25 13:01:12.104 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Link" not found
08.01.25 13:01:12.110 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Duplex" not found
08.01.25 13:01:12.114 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Baudrate" not found
08.01.25 13:01:13.222 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Link" not found
08.01.25 13:01:13.222 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Duplex" not found
08.01.25 13:01:13.223 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Ident "Status.Interfaces.Ethernet.2.1.Baudrate" not found
08.01.25 13:01:13.223 Arp.Device.Interface.Internal.DeviceStatus WARN - DeviceStatus: Disable warnings for unknown IDs starting with "Status.Interfaces.Ethernet."!
