Reconnecting GDS Port List Variables
I have a problem in PLCnext Engineer for quite a long time now. I am using PLCnext Engineer 2024.6
The problem is that when I rebuilt my project in visual studio, then sometimes in PLCnext Engineer I get errors like this.
What I then have to do is disconnect all of these variables and reconnect them exactly the same way so that the error disappears. This happens in GDS Port List.
Since I have way too many variables and this is very time consuming is there a way I can work around this bug?
Thank you for your time in advance.
  • edited January 31
    Also if I have an array of Booleans (defined as a C# Visual Studio Struct like in your CSharpExamples) is there a way to connect a specific variable of my array to an actual Plc Input or Output? I ask this because when I have an array and I go to "Select Process data item here" my options do not appear.
    At least this way the first problem would be much less annoying
  • Regarding the first problem I described: it seems to be happening when I add another variable in an already existing struct which I have already connected part of its variables in PLCnext Engineer.
  • Also if I have an array of Booleans (defined as a C# Visual Studio Struct like in your CSharpExamples) is there a way to connect a specific variable of my array to an actual Plc Input or Output?
    I defined an array of BOOLs in C#, like shown in the examples in Github.
    In PLCnext Engineer, I defined a global variable of that array type.
    I am able to connect any element of that array to a PLC input or output from the "GDS Port List" tab of the Axioline window.
  • The problem of not being able to connect array elements to digital I/O only happens when trying to connect a "Process data item" in the general IEC 61131 Page, not the GDS Port List.
  • In the Data List tab, it's also possible to connect elements of a BOOL array to a PLC input or output:
    In your screen shot, I don't know what Process Data Item (I/O variable) is supposed to match with the variable of type "Array32_Integers". Which I/O module includes a process data variable of this type?
