C# File handling
Hello!
I've tried to open a open a file for reading with a C# function block but the PLC goes to stop.
Have someone tried this functionality with a better outcome. I think  I use the correct path because when I am  using the built in file functions in plcnext engineer it works.
I've tried
if(File.Exists("/opt/plcnext/filename"))
   //Some simple code
/Stefan
  • Hello Stefan,
    could you provide me the Output Messages, please (see in /opt/plcnext/logs).
    Please send me also your complete C# FB-Code with In- and Output variables.
    Thanks!
    -Eduard-
  • Hi,
    Thanks for reply.
    The output.log and code is in attached file
    /Stefan
  • Hi Stefan,
    please define your OutputString as follows and try to execute the ReadXml() only in initialisation part :
            [Output, DataType("STRING")]
            public IecStringEx FilePath;
    Please see the Readme.txt in your Project,  and compare the following datatype documentation:
    | IEC 61131-3     |  C#
    |    STRING         | System.Iec61131Lib.IecStringEx |
    Please give me a short Feedback, if the Problem is resolved.
    Thanks!
    -Eduard-
  • Hi again,
    When i change to IecStringEx datatype i get CILG0001 internal error in plcnext
    /Stefan
  • Hello Stefan,
    please find the examples for C# FB under following link (see 05_IECString and 08_FileHandling):
    https://github.com/PLCnext/CSharpExamples/tree/master/PLCnext_CSharpExamples
    Please try only to use the example "08_FileHandling" in your application and give me a short feedback if you can successfully start it or not.
    Thanks.
    -Eduard-
  • Hi,
    Now I got it to work,
    I think the main problem was the cycle time.
    The cycle time was 2000 ms but the watchdog is not correlated to that time. When I changed the watchdog it works.
    Before I added this post I searched for plc stop information in the controller cockpit but I could not find anything. Is there going to be more information there in the future?
    Thanks for all help,
    /Stefan
  • Hello Stefan,
    in the future you will find the Status Information in cockpit under "Notifications", please see screenshot below. Additionally you can also find the Informations in   /opt/plcnext/logs/Output.log.
    Bets Regards
    -Eduard-
    Notification
