Connecting Siemens S7 300 to AXC F152 via PROFINET.
I want to connect  s7 300 ( slave) to AXC F152 (master) via PROFINET. I've got a module CP 343-1 that enables siemens conroller to be in the PROFINET network.
Is there any possibility to do that?
Thanks for your help
Mateusz
  • Hello Mateusz,
    you have to import the GSDML of your PN Device into the PLCnext Engineer Project.
    Then you can add it to your PLC as a PN Device.
    kind regards,
  • Hello Mateusz,
    after including of GSDM-Files for Siemens PN-Device in PLCnEng IDE you should be able to configure it .
    Best,
    Eduard
  • Thank for your fast replies.
    Now I've got problem with adding this files. This is the error message "Failed to import device v2.0. Interface submodule is missing".
    // I fixed it. Created new GSDML file.
