Help on IEC 104 Communication Function Block
edited December 2019 in PLCnext Engineer
I am dealing with ILC 151 GSM/GPRS PLC. I need to send PLC digital IO and Analogue IO to one SCADA through IEC 104 protocol along with Modbus TCP to other SCADA. I got Resy 104 and Resy Basic Libraries. But when I tried to get Help on FB, nothing is showing. Is there any way to get Help on FB for Resy 104 and Resy Basics library blocks in English Language?
  • Hello shahzadvs,
    please note that this Forum is for PLCnext Technology and PLCnext Engineer and not directly for classic PLC's and PCWorx 6.
    I've created a support ticket and my colleges from the  support team for Classic PLC's and PCWorx 6 will answer your question.
    For future questions about Classic controllers or PCWorx6, please contact the AUTOMATIONWORX HOTLINE at: +49 5281 9462888
    or by e-mail: automation-service@phoenixcontact.com
    Take care
    Eduard
  • Hello shahzadvs,
    I get the following reply from support team for PCWorx 6:
    "Generally, the help for the FB should be available as a PDF with the downloaded PCWorx libraries. If you need additionally support for Resy Librarys, please contact the PxC-Support team in your country".
    Please find under following Link the help file for the Resy104. There is no help file for the ResyBasic, because this is a libraty that we only use internaly to have standard funtionalities in a separate library for all the other libraries like the ReSy104.
    Best Regards
    Eduard
  • edited September 2022
    Hi experts.
    I'm using ResyBasic and Resy104 library with ILC 171. ILC works as IEC 60870-5-104 slave device.
    Can ILC connect concurrently to 2 or more IEC 60870-5-104 Remote control System?
    Thanks
