How to activate plcnext as a PROFINET controller?
good morning:
I am communicating plcnext with the sick brand gateway through profinet, I have already added the device and I have linked variables but the LEDs "BF-C" and "BF-D" are still blinking so I have not been able to establish profinet communication, The idea is that the plcnext is a controller and the sick gateway is a device, if I want to work in profinet, how do I activate profinet so that plcnext is a controller? I made this same application with a plc axc 1050 where I have the option to activate profinet controller for axc 1050 and the system worked at first without problems.
Hello rodriguez_milton,
the PN controller and PN device options are enabled by default for the PLCnext AXCF2152. Please give me more detailed information about:
1. I have already added the device and I have linked variables but the LEDs "BF-C" and "BF-D"
-> Is the device added into PN-Busconfiguration in PLCnext Engineer Project via GSDML-File?
-> It is neccessary in your project to add the gateway device into PN-Network?
-> If yes, could you provide me you PLCnext EngProject and gateway GSDML-File, if possible please?
For uploading data to the ShareFile server, please use the following server link:
https://phoenixcontact.sharefile.eu/r-rf06a5b174e44ecf8
Best Regards
Eduard
HI Eduard
Regarding what you ask me and ask
->Is the device added into PN-Busconfiguration in PLCnext Engineer Project via GSDML-File?
yes, I added the team without complications
Yes, because it is a gateway that carries all the instruments of the sick a profinet brand, they also bought plcnext precisely because it worked with profinet and also sent information to the cloud
I have uploaded images, the program and file used
Thanks in advance for your answer
