Implementing REST API with python - access token request, wrong password
I'm trying to write an application in python3 where one part of the application is an interface to the plc runtime. I managed to do it with an opcua client before, but now I'd like to use the REST API.
The controller is HW02 and upgraded to FW2020.
Currently I fail to get access to the plc. The code below is an authorisation request followed by an access token request. The response to the authorisation request will be ok[200] but the response to the accesstokenrequest will always be [401] with reason 'wrong password'
I just use the admin user with the default printed password.
def RequestAuthorisation(url):
uri = '/_pxc_api/auth/auth-token'
url = '{0}{1}'.format(url, uri)
mySecret = 'myappsecret'
payload = {
'response_type': 'code',
'state': mySecret,
'scope': 'variables'
r = requests.post(url=url, data=json.dumps(payload), verify=False)
if r:
return {
'ok': True,
'code': r.json()['code']
else:
return {
'ok': False
def RequestAccess(url, authorisationCode):
uri = '/_pxc_api/auth/access-token'
payload = {
'code': authorisationCode,
'grant_type': 'authorization_code',
'username': constant.USER,
'password': constant.PASSWORD
if r:
return {
'ok': True,
'access_token': r.json()['access_token']
else:
return {
'ok': False
Hello Jannes,
currently there is a restriction on the REST API authentication which might be causing this issue.
The Authentication only is activated correctly when you enable in a "PLCnext Engineer Projects -> HMI Webserver -> Settings -> Security -> PLCnext user management".
AND create some (empty) page + a Login Page.
i hope this solves this issue.
kind regards,
Olver.
