Export function blocks
Is it possible to export a self created function block in PLC-Next (function block created with IEC-61131 - ST-code).
In this way it is possible to import this function block in another PLC-Next application and manage a library of function block's.
Thank you, regards
Richard
there are two options available.
1. Create a Library that you can then import in every future project.(file -> export -> as IEC Library ; Libraries -> User Library -> yourLib.pcwlx)
-> Can not be modified and content of FBs can be hidden
2. Import the Functionblocks directly from the project. (file -> import -> from another Project -> select FBs you need and press Import)
-> FBs can be modified.
kind regards,
Olver
