2020.0 ICE1-8IOL-G60L-V1D GSDML Error
I updated a project from 2019.9 to 2020.0 and now I cannot map the data for the IO-Link master correctly. When I try to set the submodule type for each port, the list for the types of device is blank. The info for the IO-Link master, ICE1-8IOL-G60L-V1D, can be found in the link below. https://www.pepperl-fuchs.com/usa/en/classid_4996.htm?view=productdetails&prodid;=86682#software
Hi Rob, At the moment the workaround for this problem is to copy the Submodule from Components, and replace it under the Submodules from the IOL Master. I hope this makes sense. (if not, let me know). ~ Martin.
