Hello colleagues,
the idea: I would like to connect an AXC F 3152 as a master to several different controllers (ILC, AXC 1050, AXC3050) via profinet, and read their process data. Then i would like to write this process data from the axc f 3152 with plcnext into an SQL database. > 1st problem: When reading the profinet participants with the AXC F 3152, the controllers cannot be added. The controllers are found on the network, but cannot be added (hourglass loads briefly). Can it be due to an outdated firmware of the different controllers? I can easily add an AXC F 2152. Thank you for the help and best regards, > > Simon >
