Adding additional target to Eclips Project
Hi All!
I’ve an eclips project that builds for an RFC4072, for debugging purpuses I would like to build the same project for an axcf2152.
Both SDK’s are installed but I’m not able to find the right settings. Can you help me out? Can I replace the target, or better, build the same projects for both targets? With kind regards Dries
Hello Dries, you can do that in Eclipse Project-Properties via Add/Remove Targets. Best Regards Eduard Unbenannt
Thank you for the fast and accurate answer!
Thank you for your good feedback!
