Alarms_1_3 example does not open
Anyone else getting this same error when opening the Alarms_1_3 example, downloaded from PLCNext store ? Using latest version of PLCNext engineer 2021.6.1 See attached.. Thanks
That project opens OK for me in PLCnext Engineer 2021.6 (build 4.10.142.0). There have been reports of the same error message with corrupt PLCnext Engineer projects. Perhaps this example project has been corrupted on your machine somehow . Can you please try running the installation package for that library again?
Thanks for your help Martin, I re-installed and had the same problem, also tried on a different PC and same problem. Would you mind saving the Alarms project, and attached it to this thread ?
Unfortunately it is not possible to attach PLCnext Engineer projects here, so I have sent it by email. (please check your spam folder if necessary).
