A customer is asking if the PLCnext is able to run APACHE open source software. If so, do we have some user case using this platform? Another question is regarding to Proficloud buffer in the AXC F 2152 What is the memory type where the data is recorded when communication is lost? RAM, Flash ou another one? Does the data is lost after a power cycle? I know it depends on the memory type. Additionally, the customer asks if the Linux OS version of the AXC F 2152 supports containerization. Is it possible?
Apache In theory it is possible to run Apache software. The customer can cross-compile Apache for their chosen PLCnext target, or they can try installing the binaries from a public repository (e.g. the httpd package from guix or the apache package from Optware-ng). Note that each PLCnext Control already includes the nginx web server, in case this helps. Proficloud data buffer Currently, Proficloud data is buffered in RAM and so if the connection to Proficloud is lost, then any buffered data will be lost if power to the PLC is cycled before the Proficloud connection is restored. Containerisation The current versions of the PLCnext Control OS, as delivered from the factory, do not have the kernel settings to support containerisation. If this is required then a custom kernel must be built. This is an increasingly common request, so if your customer needs this, please give us more details and we can help decide on the best approach. - Martin.
