After transmission the project data to the Controller 2152 I get an error as showed in the picture Error_01[attachment]Error_01.jpg[/attachment]
Hello, probably you need to configure AXL SE SC modules to signal that the other slots of your SE Base module are empty. If you hover over or click the Axio Error you should see the error codes You can see more details in the SystemVariables AXIO Master or the WBM of your PLC.
