Hello colleagues, please, could you tell me, why I am not able to assign IP address from project to cotroller? I add screenshots:
I use PLCnext Eng. 2020.3, controler AXC F 2152, HW 02, FW 2020.0.1 LTS. Thanks for help, Roman
I also experience a similar issue with PLCnext Engineer 2020.3 and 2020.6. When I select my wired Ethernet adapter, all functions of the “Online Devices” fail to work. When I select my wireless Ethernet adapter, all functions work as expected. Additionally, after selecting my wireless Ethernet adapter, I am not able to connect to the controller, log into the controller, or download to the controller. I must switch back to my wired Ethernet adapter for these functions to work. All prior versions of PLCnext Engineer worked as expected. Did the fix for remote VPN connection with PLCnext Engineer break something? Thank you, Loren
Hello Loren, do you think, that earlier version of plcnext eng. was ok and newer versions have this bug? Roman
Have you tried to install the NCAP PACK DRIVER (NPCAP) (WiFI) and NCAP PACK DRIVER (NPF) (WiFI)?
Hello, no, I don’t tried it. It didn’t work in same time on three different pcs during training of PLCnext Eng. at customer. Do I have to install it (NCAP PACK DRIVER (NPCAP) (WiFI) and NCAP PACK DRIVER (NPF) (WiFI)) separately on every PC? Roman
