Availability of ControlTechnology library
Hi, I’m testing the new PLCnext Engineer IDE together with the AXC F 2152. I’m looking into the possibilities to port an existing IEC61131-3 application from PC Worx 6. I have imported datatypes and POU’s via the import/export PLCopen functions in both PC Worx and PLCnext. However, the application utilizes the ControlTechnology library (i.e. for the functions POLG_N, LAG1ST and LIMITROC). This library does not seem to be available yet for PLCnext Engineer. Is there a possibility to import the old library, or does Phoenix Contact need to port the library?
Hello David, As discussed on the Phone, we supplied you with a converted library This library is not tested and you will use it only for testing purposes
Kind regards,
Jan-Willem
