AX_Control Function Block
I’ve been experimenting with the Dynamic Axiobus Configuration application by Gianluca Riboldi and the BusConductor library. I’m looking for more information on the AX_Control function block and the firmware services (codes, etc.) so I can better understand the process of configuring the local bus.
Hi Aaron, There is a document that describes the codes that are used with these Axioline functions, but it does not seem to be available on our website. If it’s OK with you, I can send the document to the email address you gave when registering on this forum. ~ Martin.
Thanks Martin
Hi Martin,
I’m also working with the AX_Control block (using the project from Gianluca as a basis) and would like to receive the document about these functions. Is it already available on your website or could you send it to me?
Hi Bert, that document is still considered internal, and so is not published on our website. It shouldn’t be a problem to get a copy to you. Someone from your local Phoenix Contact office will get in touch.
