AXC 1152 Execution Time
i Just Want to Confirm Some Imporatant Feature for AXC 1152 Controller.
1) Execution time for 1 KInstruction = ?  (0.3 ms for event and periodic task)
2) Execution time per instruction = ? ( near to 0.022 µs or less?)
Hello harshid,
the \tArm® Cortex®-A9 1x 800 MHz is used in the HW of AXC 1152 Controller. If I assuming that one instruction takes 10 clock cycles: 10/800MHz = 0,0125µs. Please note, the timing of an instruction is often affected by other concurrent instructions, memory system activity, and additional events outside the instruction flow. Detailed descriptions of all possible instruction interactions, and all possible events taking place in the processor, is beyond the scope of support in this forum.
If you would like to measusre the program execution time, I would like to recommend you to use the std::chrono::system_clock class in C++ API.
Best Regards
Eduard
Hello Eduard,
Thanks for your Quick Response on this.
I will Definetly Measure with C++ API. , Thansk again.
