we have a developed a solution with an AXC F 1152. One customer requires an additional network port. Is the AXC F XT ETH 1TX also compatible with the 1152? We want to keep the current setup and the 2152 it is not available.
Unfortunately, the AXC F 1152 does not support any left-alignable AXC F XT modules.
Adding AXC F XT modules (plcnext.help)
Will it ever be possible to connect the module to the AXC F 1152? Or is it technically impossible?
It’s difficult to say that something like that is technically impossible, but when the AXC F 1152 was designed the deliberate decision was made to remove features from the AXC F 2152 (like the left-side connection) to reduce the cost. If these features were added in the future, then the AXC F 1152 would cost the same as the AXC F 2152.
If I was to make a bet, I’d say that it will never be possible to connect left-side modules to the AXC F 1152.
