AXC F 2152 loses network connection after changing IP address
Hello everyone,
I’m experiencing a strange issue with my PLCnext AXC F 2152.
Whenever I change the device’s IP address (either via WBM or PLCnext Engineer or SSH), the controller immediately becomes unreachable on the network.
After that:
The PLC does not respond to ping
  • It doesn’t appear with any IP address on the network.
  • In Wireshark , I can only see LLDP packets from the controller (e.g. Port Status = OFF).
  • → So the interface seems physically active but software-disabled.
  • Environment:
    Device: AXC F 2152
  • Firmware: 2024.6.1
  • PLCnext Engineer version: 2024.6
  • Connection: LAN1 (eth0)
  • Method of change: [WBM / PLCnext Engineer / SSH]
  • Question:
    Is this a known issue or configuration bug?
  • How can I reliably change the IP address without losing connectivity?
  • Is there a recommended way to reset or verify the network configuration after IP changes?
Thanks a lot for your help!
Best regards,
Josef
Hi Josi,
can you try to clear your arp table and see if that works? That helped me in the past when I faced that issue.
Commandline → arp -d
BR
DivisionByZero
Hi DivisionByZero,
thanks a lot for the „arp -d“ tip!
  1. I logged in as admin via SSH,
  2. switched to root user using su
  3. ran ip neigh flush all (as an alternative to arp -d)
  4. changed the IP address via WBM
Now it works, the controller is reachable under its new IP address.
Thank you!
BR
Forgot to mention that you have set a root password before switching to su:
  2. set root password using sudo passwd root
  3. switched to root user using su
  4. ran ip neigh flush all (as an alternative to arp -d)
  5. changed the IP address via WBM
Thank you!
BR
