AXC F 2152 update failed, no contact to the controller possible
After an attempt to update the AXC F 2152 via WBM, the update started as usual, but after restarting the controller, it no longer responded. A login is no longer possible Error message Bad Gateway.How do I get back in touch with the controller?
Pressed the reset button, set the control to factory settings via the cockpit, now it works.
