AXL F IOL8 2H - 1027843 implemetation
At the moment I try to implement the new AXL F IOL8 2H - 1027843. I use the 2019.3 FW and SW version. On the website I downloaded the FDCML3 file for import. It is included in the Components Area. It seems that this type is restricted for use directly on the Axioline-bus behind the Controller. There was some communication that it could only be used behind a PN BK. This module type is not included in the component area ‘Axioline F Profinet’. A newer FDCML3 for the 2701815 can’t be found also. How to implement the 1027843 behind the PN BK 2701815? Second remark. If I choose to configure the AXL F IOL8 2H behind the Controller on Axioline-bus you should use for Acyclic communication the IOL_Basic Function block and the AsynCom_AXL function block from the AsynCom_6 library. It seems that the IOL_Basic communication block doesn’t work properly because I get the wDiagCode 16#C100 wAddDiagCode 16#00000000. It suggested that there is a timeout on Profinet. That doesn’t make sense because I use it behind the controller and I have no PN communication.
How to solve this problem.
I can send you a demo project for both application - direct on the controller and on a BK.
Okay. If you have, I would be very happy. Could you upload it to the Forum? tnx
I will upload it to the forum today but not later as tomorrow. Peter Paul
It is not possible to upload a zip file to the forum. e-mail? Peter Paul
Same here. I try to get valid Data from the module, but get nothing. Is it possible to rename the Examples to .pdf and upload them? I would be very happy if I could get a concrete example. Gruß, Manfred
