Dear Community,
I´ve been trying to use the examples of the AXL_PDI 7 Build 20201119 (there are two with this name, I first used the last one).
* Example AXL_PDI_7_EXA_AXL. PLCnext Engineer can´t /convertopen this and the progress bar gets frozen at the begining of the loading.
Example AXL_PDI_7_EXA_PN. The code of “ExampleMachine_1” is not the same as the one is in the library manual, and it doesn´t work: 1. Inputs xDiag and dwNodeID are missing. 2. Once xStart is activated, AXL_PDI_R_W is momentarily activated and then it gets off.
The point is that the earier Build 20201119 works properly with both examples, and codes match with the ones are on the library manual.
PLCnext Engineer I´m using: 2023.0, Build 6.0.2570
If I am not mistaken, the examples of the las build should be reviewed.
Thanks.
