Best communication method between PLCnext AXC F 3152 and Siemens S7-1500 / S7-300?
Hello everyone,
I am currently planning a communication architecture between a PLCnext AXC F 3152 and Siemens PLCs (S7-1500 and S7-400/300).
Before deciding on a specific implementation, I would like to ask for general recommendations regarding the best communication approach for this setup.
Requirements:
  • Communication between:
    • PLCnext AXC F 3152 ↔ Siemens S7-1500 and S7-400/300
  • Ideally one solution that works for both Siemens PLC types
  • Reliable and maintainable solution
  • Ability to exchange structured / larger datasets (not just single bits)
From my understanding:
  • PLCnext supports multiple protocols such as PROFINET and OPC UA
  • S7-1500 supports modern standards like OPC UA and PROFINET out of the box
  • Older S7 systems may have limitations depending on communication method
However, I am unsure which solution is considered best practice in real industrial environments, especially when mixing different PLC platforms.
Thanks in advance!
The question is not so easy to answer,
If the controllers that are to be connected to each other are bundled together in a system area, I would always prefer a Profinet connection first:
For example, the 3152 as Profinet master and the Siemens controllers to the Profinet device.
Due to the different network connections X1-3 of the 3152, it can communicate with a higher-level system on X1 and then act as a PN master on X3.
However, if the controllers are all stand-alone, an OPC UA connection to a control system may be the better choice.
