Board temperatur
Hello, I would like to read and display the temperature of the CPU. I am using the variable deviceState.BOARD_TEMPERATURE but it always reads zero. I am using PLCEngineer and Firmware 2020.3. How to do this? Thanks, Alex PLCNext temp
Hi Alex, What data type is your deviceState struct? How have you linked this to the global variable DEVICE_STATE ? If you add the DEVICE_STATE global variable to the Watch window while you are online, do you see the correct BOARD_TEMPERATURE value there? ~ Martin
Thanks Martin, Your suggestion helped. It is working now. Regards, Alex
