Button 'command execute' in Engineer 2021.0.2 gives error
Just did a simple test to start a web page by a url command. But I get a error message; ‘The expression contains an syntax error.’ See attachment. If I use Engineer version 20.20.6.2 it gives no error message. My current version is 2021.0.2 build :4.7.1183.0 Kind regards, Wilco
Hi Wilco, Please try putting the URL in single quotes. I will raise this as an error in the documentation for PLCnext Engineer, which indicates that quotes are not required. ~ Martin.
That works. Thanks. Kind regards, Wilco
