Can i confirm that you can only create C++ programs or services, and not callable function blocks that could be used within a structured text program in PLCnext Engineer?
I was able to create function blocks in C# using FunctionBlock decorator on the class, but there doesn’t seem to be an equivalent for C++
Confirmed.
Can i confirm that you can only create C++ programs or services, and not callable function blocks that could be used within a structured text program in PLCnext Engineer?</p>
I was able to create function blocks in C# using FunctionBlock decorator on the class, but there doesn’t seem to be an equivalent for C++</p>
Hi steveo1011,
Please refer to the link below. The approach to achieve it is a combination of C++ deployment and C# wrapper. Would this solution work for you?
https://www.plcnext-community.net/infocenter/function_blocks_in_cpp/
