C++ programming in Visual Studio and Eclipse
Hey all,
I was trying to open a Eclipse project in Visual Studio. Off course I am able to open the folder and change the textfiles (hpp and cpp's), but is it also possible to use both programs parallel to build the library? I doubt it is possible due to different plugins, but I was just wondering...
Arne
Yes this should be possible. The two different plug-ins could be installed on the same machine and should not interfere with each other. Underneath they both perform the same functions, e.g. they both call the same plcncli commands under the hood.
Edit: Actually now that I think about it some more, it might be more complicated than that. The Visual Studio project will include a .sln file and .vcxproj file, and the Eclipse project will include its own project files. But these might not interfere with each other, if the IDE-specific files have different extensions (and I'm pretty sure they do). It might take a few tricks to get both IDE projects set up on the same source files, but once that's done I think it should work OK.
Allright, in that case I will investigate and update this post after! Thanks.
We have chosen to use visual studio code and defined the needed plcncli commands in tasks. That way I am still able to build with hotkeys and have the nice interface of VScode :slight_smile:
In addition on this, I thought I have seen the vsix file for C# programming somewhere in the folders created by the toolchain installer. That way it would be possible to also make VScode capable of creating C# libraries I guess. I suppose it was in the ide-plugins folder one time.. Where can I find that file to check if it’s possible to use VScode? Or should I configure that a different way / is it only usable in Visual Studio 2019?
With the latest version of the PLCnext CLI (2021.6), the Visual Studio add-in is installed directly into Visual Studio if (a) Visual Studio is detected on the machine during installation, and (b) if you choose to install it.
This extension can only be used with Visual Studio, not with Visual Studio Code.
Allright, thanks!
