CAN_Basic_5 Problems set mode to operational
Configuration:
  • PLCnext Engineer 2024.0.4 LTS
  • AXC F 2152
  • AXL F IF CAN 1H
  • 1 Servo Drive (CANopen)
I am using the CAN_Basic version 5 library from the PLCnext store. I have an issue with the CAN_CO_Functions function block. After configuration of the SDO and PDO mapping I want to set the NMT mode to Operational. But when trying to do so the output iOP_Mode will not set to 2.
Below is the sequence I follow:
  1. NMT reset
  2. NMT pre-operational
    2.1 Set SDO parameters
    2.2 PDO remapping of TPDO & RPDO
  3. NMT Operational (Doesn’t work)
The function block is going to be set to Busy and set to Done but the iOP_Mode stays at 3.
I do set the iFunction = 3 & iOP_ModeSet = 1.
Now I cannot verify if the node is in operational. Is this something within the library block or something with my node?
When I skip this verification I also get an EMCY failure when I tried to activate the SYNC function.
Emergency message:
Communication Errors (CANOpen)
COM_CONFIG_ERROR - Erroneous configuration of PDOs - CiA301: 0x8240
sorry for the delayed answer. If you didn’t already get in touch with the CAN library developers on an other way, we recommend to use the “Contact Developer” button in the PLCnext Store for App support.
