Hallo PLCnext Community,
I am working on a project with AXC f 2152 Controller module and AXL F IF CAN (2702668) Can Module to communicate with Phoenix Contact TRIO-HP3AC1KDC20KWBI DC Power Supply. I downloaded the CANbus 11 Library and referred to the Library files and Examples. I have a successful connection with the PLC already. I am just trying to send a simple CAN message but I am unable to successfully change the Baud rate or send a Message. I connected a CAN logger to the loop to see if something is being sent or not. I have not written my own program for it but simply modifed the E1000 program from the CAN_11_EXA_AXL.pcwex Project to just send a message. According to the CANbus 11 datasheet, I just changed the udtExample to 1000 to execute the first Program and Activated the Bus. I am not able send or receive anything. I do have added additional 120 ohm resistance as well in the loop.
Another Problem I am facing in general is I am not able to find the CAN messages needed to control the above DC Power Source from Phoenix Contact online.
Looking forward to any help and guidance from the experienced community here
Thank you,
Best Regards,
Aadi
