I would like to ask for advice, if I successfully find my PLC device AXC F 2152 in PLCnext Engineer, I want to connect to it using the login and password. The problem is that the entered data is apparently incorrect. I use “admin” as the login and the password is what is on the PLC label. I would like to ask where the problem could be and how to solve it. It occurred to me that a previous user could have changed the name or password and not reset the PLC afterwards. I also cannot log in to the PLC web interface. Is there a way to reset the PLC directly on the panel so that the login data is reset on it? Thank you for all the advice
Hi PLosert,
there’s a reset button at the front of the PLC (behind the paper sheet).
Please check the manual “um_en_axc_f_x152_107708_en_13.pdf”.
You can find it here: AXC F 2152 - Controller - 2404267 | Phoenix Contact
BR
DivisionByZero
