Hello, Can the USB type-C interface on the AXC F 2152 PLC be used at present? We want to use this interface to connect USB wireless network card or USB serial port and other hardware. Thanks!
to my knowledge its only possible to use this interface as a USB Device
so you will not be able to use a Wireless network Card.but you should be able to connect a USB master like a PC to the PLC.
Dear Sir, Please let me know , can we use USB port as serial port ? Regards Chetan
Hello Chetan, currently the power supply (5V) of the USB type-C interface is not supported and the serial UART needs a internal power supply for signal generation. Currently you can use the following modul for Serial Communication: AXL F RS UNI 1H - 2688666 Best Regards, Eduard
Ok Sir
