Hey I am trying the openCV for PLCnext control (https://www.plcnext-community.net/index.php?option=com_content&view;=article&id;=266:opencv-with-plcnext-controls&catid;=78&Itemid;=366⟨=en) but i’m stuck at the part where FFMPEG needs to be compiled. After the ./config.sh command i always get the same error: WARNING: arm-pxc-linux-gnueabi-pkg-config not found, library detection may fail.
WARNING: Building with deprecated library libavresample Is there a way to manually insert this library or can I find this library somewhere else? Thanks in advance!
Hello, Sorry for the delay. I am guessing that no one in the Community has tried the procedure described in that Makers Blog post recently, so I have had a quick look. Firstly, can you please check that the paths to the SDK are all correct for your installation. In the Makers Blog post, this is shown as /opt/pxc/2.2.1, but you need to change every instance of this to the path where you installed your SDK. On a more general point, that Blog post is now two years old and there may be better way to cross-compile ffmpg and opencv. I have had some success with vcpkg, and others have had good results using conan. Perhaps you could give these a try if you have no luck with the the Makers Blog procedure. ~ Martin.
