Hi I have experienced a lot of trouble when i have forced variables. PLCnext Engineer will not connect to the PLC when there is forced variables. I can only do a full download, and start again. Pretty annoying. The same with download change fx. in the fast edit function. I have attached a video about the problem. There is no information about it’s the force there is the problem… The same with debug, without the matching source code isn’t possible, like it is in PcWorx 6… https://youtu.be/AKqlzGO4LtA [video]https://youtu.be/AKqlzGO4LtA[/video]
Hello Emil, thanks for the detailed error description and video, could you send me the used PLCnEng Version, PLC/FW Version and used PLC Teplate in Project, please? Thanks & Best Regards Eduard
Hello Emil, I can reproduce the following behavoir with the FW 2021.6 and PLCnEng 2021.6: PLCnext Engineer can not allways starts the debug mode after download chages, when there are forced variables (by using of „fast edit function“ ). This defect is provided to development and will be analyzed. Best Regrads Eduard
Hi, Any news on this?
It’s still a problem in 2022.0.1
I haven’t tested it in 2022.3 yet
-Emil
It seems that the earliest this will be fixed is in version 2023.0 LTS.
(ref: #219169)
