Can't reinstall app after FW update
Hi I have installed IXON App on my 2019.3 controler. it was running at 100% cpu load, so i tryed to factory reset the cpu.
It helped a little on the cpu. But now i updated to 2019.6 istead. Now i want to install the APP again, but i cant, because it says it allready installed? I cant get the controller online at the Proficloud, I had the same problem first time i tryed, and then it helped to remove the controller and add it again. But i cant remove it because it says the app is installed? What to do then?
Hi when a firmware update is performed the apps remain on the device.
After a firmware update or a device reset is is performed, the device is not able to connect to the Proficloud or the PLCnext Store. This has security reasons.
Please try if this FAQ helps to solve your Problem: Link: I reset my PLC and now it always appears “offline” in the Store. What should I do?
