Certificate verification failed during installation of balena-engine
Hello support team, I am trying to install balena-engine on an AXC F 2152 with firmware 2020.3.1. When I enter the git clone command to install balena-engine, I receive a message that a certificate cannot be verified (see attached image). I have reseted the controller to factory defaults and updated the firmware but the result is the same. What can I do?
Hey Stephan,
please check permissions on the folder.
I guess you did a Type 1 reset?
Please also check the /media/rfs/rw/upperdir/etc/ssl/certs/*
For a quick help, ignore the certificate. (Of course we don’t normally do ignore cert :slight_smile: ).
GIT_SSL_NO_VERIFY=true git clone https://
After consultation it was a type 2 reset, but he is root on his attempt. I think it’s strange. Maybe the file is broken after the reset?
