Change Mode LAN Ports AXC F 1152
Hi, the WBM shows that the LAN Ports of the AXC F 1152 are in switched mode. Is there a way to change it to unswitched mode and use the ports for two separate networks? I found already the extension AXC F XT ETH 1TX for that situation as solution, but to change the network mode would be the much more better. In this post Redirecting to new forum... Frank said, that in future releases it will be possible to assign separate IP addresses to the ports (but for the AXC F 2152). Thanks!
Hi beecksche, yeah we know this requirement very well and have it also in our backlog. But the impelementation is not trivial and will defenetly not come this year. So for now, you’ve to use the ETH XT or e.g. the AXC F 3152 which comes native with three indipendent NICs. Take care, Frank
is the AXC F XT ETH 1TX compatible with the AXC F 1152?
