Changing the axc f 2152 ip address
Hello i tried to change the ip of the axc f 2152 folowing this guide (https://www.plcnext-community.net/index.php?option=com_content&view;=article&id;=322:setting-up-an-internet-connection-axc-f-2152&catid;=78&Itemid;=366⟨=en) but now only the D (led) in on and i can not conect to the controller through putty or plcnext engineer. any ideas?{jcomments on}
most likely you made some kind of spelling or formatting error in the Config file.
Due to that the PLC can not boot anymore. Because of these risks it is not recomended to change the IP manually.
Do you have a external SD Card?
You can Mount that in a PC with Linux Filesystem support to edit the file manually.
Be carefull not to delete or format the SD Card!
** You can also do a factory reset to restore the IP to shipping state.
Type 1 Reset should be enough.
kind regards,
