CILG0001 - Update from PLCnext Engineer 2022.3 to 2023.0.5LTS
Hi All,
I am trying to convert a project built with PLCnext Engineer 2022.3 to the 2023.0.5 version.
I am using Modbus TCP 11 library that at first produces the SEM1100 error which was mentioned also here: https://www.plcnext-community.net/forum/#/discussion/3136/updating-libraries
After updating library to Modbus TCP 12 I get a CILG0001 error every time I try to build the project, that no matter what I tried to change does not get resolved.
Any insight/help on this?
Thanks in advance
Vaggelis
Hi! Try Modbus TCP 13 library.
Hi! Try Modbus TCP 13 library.</p>
Trying to add Modbus TCP 13 I get:
Could not load library “Modbus_TCP_13.pcwlx” due to a breach of integrity. (MSG_PRJ0024)
It looks like version 13 was released for 23.6
[https://forum.plcnext-community.net/uploads/MHWEFM3AG1FX/image.png</a></p>It looks like version 13 was released for 23.6</p>
Missed that…
Does the error occur when using the Modbus 12 lib in other projects?
Does the error occur when using the Modbus 12 lib in other projects?</p>
No, but the projects I use it in were created with 2023.0.5 Engineer version.
I suggest you’ll get in touch with the PLCnext team or Phoenix Contact support then.
The PLCnext Engineer support team have been made aware of this issue, so I hope there will be an answer soon.
The PLCnext Engineer support team have been made aware of this issue, so I hope there will be an answer soon.</p>
Thanks Martin!
Hi Martin, any news about this issue?
I understand that someone from Phoenix Contact who was involved in the original project is now working through this issue with you.
I understand that someone from Phoenix Contact who was involved in the original project is now working through this issue with you.</p>
Yes Martin, the problem was resolved by upgrading PLCnext Engineer to latest version(2023.6) and using Modbus TCP 13 library.
Thanks for your time!
