Codesys Device Tree and bussing error/diagnostics
Hi, I am having an issue with the PLCnext and the busing to the IO cards. I am unable to communicate with the IO cards and the diagnostics on the web based management only says there is a bus error. I was wondering if anyone has experienced this before and if there is a solution. I have verified I have the right parts in the device tree and also that the devices themselves are working correctly. Any help in solving this is greatly appreciated! Thanks in advanced! Mitch
Hi Mitch, Hopefully a Codesys user will see your question here and be able to help, but you might also want to contact 3S - they will probably be able to support you on this issue. Regards, Martin.
