Hello, could someone share information about the OPC_UA configuration of PLC NEXT with VISU + 2.52 REGARDS.
In Visu+: Right Click “OPC UA Client” and then select “Add New OPC UA Tag…”.
* Once you have selected “Add New OPC UA Tag…” You will then see the Tag Browser window appear. * In the Tag Browser, click “Add Endpoint”. You will then see the New Endpoint window appear. * Enter in the PLC Next Server URL in the Endpoint section. * Drop down the security box and select “SignAndEncrypt”. * Enter the User Name and Password (this will be the same as the PLC Next credentials).Click “OK” in the New Endpoint window Click “OK” in the Tag Browser window and you have now established connection between your PLC Next and Visu + Express via OPC UA communication.
