Buenos dias Me gustaria saber como realizar la configuracion entre el PLC AXC F 1152 y el TC Router 3002T - 4G, mediante el puerto TCP/IP ethernet en que manual puede revisar. Muchas gracias Anderson Rodriguez
Hi Anderson, I hope this is the correct translation (thanks Google):
good morning I would like to know how to configure the configuration between the AXC F 1152 PLC and the TC Router 3002T - 4G, through the TCP / IP ethernet port in which manual you can check.
From the PLC’s point of view, the TC Router is just another router, so you can set up the PLC in the same way as you would for any other router. To configure the TC Router, you can refer to the User Manual, which you can find in the “Downloads” section of the product page: https://phoenixcontact.com/product/2702528 (only available in English and German, sorry) Please let us know if you need any more information. Alternatively, you can get application-specific support from your local Phoenix Contact subsidiary. Saludos cordiales, Martin.
