Connecting 1 OUTPORT to Many INPORTS
I want to work with several program’s on 1 controller. 1 program is a kind of overal runtime handler which handles, for example, the reset handling. I want to push the resetsignal, detected in the runtime handler to all other program;s. Working with a global variable is not possible because the scope from a variable can not reach beyond the runtime. So i want to make the resetsignal an OUTPORT for the runtime program and INPORT for all other program’s.. Is this possible? And how? Thanks, Marco van Os GeoComfort
Hello, You can duplicate the OUT port using the context menu in the PLCnext Engineer “Port List”: 2021 01 29 10 54 38 … then you can connect the duplicated OUT port to another IN port. Hope this helps. ~ Martin.
