Hello, I want to connect s7 300 ( slave) to AXC F152 (master) via PROFINET. I’ve got a module CP 343-1 that enables siemens conroller to be in the PROFINET network. Is there any possibility to do that? Thanks for your help Mateusz
Hello Mateusz, you have to import the GSDML of your PN Device into the PLCnext Engineer Project. Then you can add it to your PLC as a PN Device. kind regards,
Hello Mateusz, after including of GSDM-Files for Siemens PN-Device in PLCnEng IDE you should be able to configure it . Best, Eduard
Thank for your fast replies. Now I’ve got problem with adding this files. This is the error message “Failed to import device v2.0. Interface submodule is missing”. // I fixed it. Created new GSDML file.
