Hello everyone, I am trying to use the balena-engine as descripted in https://github.com/PLCnext/Docker_GettingStarted/blob/master/getting-started/README.md On a fresh AXC F 2152, with firmware 2020.0, i can run containers but the containers dont have connectivity to the network. They only can reach the PLC ip. The firewall is disabled. In the picture you can see the preblem following the example (ping 8.8.8.8 from a debian image) I think the problem is that the PLC can´t Forward packages from balena0 to eth0. The ip_forwar aparently is active
Networks in the PLC:
and ping from container to PLC:
Could you help me with this? is there another configuration necesary?? Best regards. Andrés.
Hi Andrés, It looks like nftables has not been set up correctly,. I think the balena0 adapter must have an ip address in the network 172.18.0.0/16. when you execute the command /etc/init.d/balena start, you should see the message:
loaded firewall rules for docker (/etc/init.d/balenafw start) > load firewall ruleset for balena >You can see in the
balenafwscript, the ruleset from the file/etc/nftables/balena.nftis loaded by nft. You can check that this configuration is correct with the command:nft list rulesetThe result should be:
table ip docker { > chain docker_forward { > type filter hook forward priority 0; policy drop; > ip saddr 172.18.0.0/16 oif "eth0" accept > ct state established,related accept > } > chain prerouting { > type nat hook prerouting priority 0; policy accept; > } > chain postrouting { > type nat hook postrouting priority 0; policy accept; > ip saddr 172.18.0.0/16 oif "eth0" masquerade > } > }Is this what you see? ~ Martin.
Thanks Martin, I changed define balena_v4 = 172.18.0.0/16 for define balena_v4 = 192.168.0.0/24 in /etc/nftables/balena.nft and is working now
